25 kg
Capacity
210 mm
Max Part Dia.
1831 mm
Reach
6
The Haas Robot Package 2 is a fully integrated, plug-and-play, 25 kg capacity robot system for Haas machines. The system is controlled entirely from the Haas control. Includes: 6-axis robot, mounting pedestal, (1) parts table, software interface for direct control through the Haas machine, electrical interface box, safety guarding, and all necessary solenoids, hardware, and cables.
25 kg Max Capacity (part + gripper)
Suitable for Haas medium vertical machining centres, UMCs, and ST-20 through ST-35 turning centres
N.B. Specifications subject to change without notice.
| Axes | S.A.E | METRIC |
| Controlled Axes | 6 | 6 |
| Capacities | S.A.E | METRIC |
| Max Load Capacity at Wrist | 55.0 lb | 25 kg |
| Reach | 72.1 in | 1831 mm |
| Repeatability | 0.0008 in | 0.020 mm |
| Single Gripper | S.A.E | METRIC |
| Max Part Weight | 30.0 lb | 13.6 kg |
| Gripper Assembly Weight | 17.7 lb | 8.0 kg |
| Part Size - Round ø | 1.00 in to 8.25 in | 25 mm to 210 mm |
| Part Width - Rectangular | 0.55 in to 6.50 in | 14 mm to 165 mm |
| Part Length - Rectangular | 1.00 in to 5.50 in | 25 mm to 140 mm |
| Dual Gripper | S.A.E | METRIC |
| Max Part Weight (per gripper) | 18.0 lb | 8.2 kg |
| Gripper Assembly Weight | 14.6 lb | 6.6 kg |
| Part Size - Round ø | 0.63 in to 6.20 in | 16 mm to 157 mm |
| Part Width - Rectangular | 0.38 in to 6.00 in | 10 mm to 152 mm |
| Part Length - Rectangular | 0.90 in to 2.20 in | 23 mm to 56 mm |
| Motion | S.A.E | METRIC |
| Motion Range – J1 | 340 ° | 340 ° |
| Motion Range - J2 | 260 ° | 260 ° |
| Motion Range - J3 | 458 ° | 458 ° |
| Motion Range - J4 | 400 ° | 400 ° |
| Motion Range - J5 | 360 ° | 360 ° |
| Motion Range - J6 | 900 ° | 900 ° |
| Speeds | S.A.E | METRIC |
| Max Speed - J1 | 210 °/sec | 210 °/sec |
| Max Speed - J2 | 210 °/sec | 210 °/sec |
| Max Speed - J3 | 265 °/sec | 265 °/sec |
| Max Speed - J4 | 420 °/sec | 420 °/sec |
| Max Speed - J5 | 420 °/sec | 420 °/sec |
| Max Speed - J6 | 720 °/sec | 720 °/sec |
| General | S.A.E | METRIC |
| Mounting Method | Pedestal Mount | Pedestal Mount |
| Weight | 551 lb | 250.0 kg |
| Dimensions - Shipping | S.A.E | METRIC |
| Domestic Pallet | 85.0 in x 85.0 in x 64.0 in | 216 cm x 216 cm x 163 cm |
| Export Pallet | 85.0 in x 85.0 in x 64.0 in | 216 cm x 216 cm x 163 cm |
| Weight | 1740 lb | 790.0 kg |
| Domestic Crate for Safety Fence | 79.0 in 53.0 in 34.0 in | 201 cm 135 cm 86 cm |
| Export Crate for Safety Fence | 79.0 in 53.0 in 34.0 in | 201 cm 135 cm 86 cm |
| Weight for Safety Fence Crate | 1,200 lb | 544.0 kg |
The Haas HRP-2 is a 25 kg capacity robot system that is fully integrated with the Haas control. The system features plug-and-play connections so it’s easy to connect to a Haas mill or lathe and is controlled entirely from the Haas control.
Haas has three different Plug & Play Robot packages of varying sizes. In this video, we look at each of the three robot packages; what you get in the package, their capacity and reach, and the machines that each package will fit.
When you get a Haas Robot Package you get a Plug & Play system that is ready to go out of the gate. Manufacturing Engineer Mallory Tevini gives us a bunch of great examples of ways you can make your robot cell fit your shop’s circumstances perfectly.
There’s never been an easier way to add a 6-axis robot to a Haas machine. With Haas Robot Packages, you set up and control the robot directly from the Haas control, with no need for complex PLC connections or a 3rd-party integrator.
We’re here to answer all of your questions about adding a robot or cobot to your shop.
For details email us, or call 01603 760539.
