Haas VF-6TR 5-Axis Vertical Machining Centre
Haas VF-6TR Specifications
X Axis 64"  1626 mm
Y Axis 32"  813 mm
Z Axis 30"  762 mm
A Axis (tilt) ± 120°  ± 120 °
B Axis (rot) 360°  360 °
Spindle Nose to Table (~ min) -6.21"  -158 mm
Spindle Nose to Table (~ max) 23.8"  605 mm
Max Speed 8,100 rpm  8,100 rpm
Rapids on X 540in/min  13.7 m/min
Rapids on Y 600in/min  15.2 m/min
Rapids on Z 600in/min  15.2 m/min
Max Cutting 500in/min  12.7 m/min
Max Thrust Z 5600lb  24910 N
TRUNNION S.A.E. Metric
Platter Diameter 12.2"  310 mm
Max Weight on Platter 500lb  226.8 kg
Max Part Swing (reduced at tilt angles > ± 90°) 31.0"  787 mm
T-Slot Width 0.625"  15.88 mm
T-Slot Quantity 6
Pilot Bore Dia 3.250"  82.6 (+ 0.0127, –0.0) mm
Pilot Bore Depth Through  Through
Rapids on A 3000°/min  3000 °/min
Rapids on B 3000°/min  3000 °/min
Max Cutting A 2000°/min  2000 °/min
Max Cutting B 2000°/min  2000 °/min
Max Tool Diameter (adjacent empty) 6"  152 mm
Max Tool Length (from gage line) 16"  406 mm
Tool-to-Tool (avg) 2.8sec  2.8 sec
Chip-to-Chip (avg) 3.6sec  3.6 sec
Machine Weight 22850lb  10365 kg
Click for CNC machines
